Height of mg factory hardtop (inside) 640mm ???
Bman new zealand
Forename: Bevan
Surname: Martin
Post by Bman new zealand » Thu Sep 26, 2019 6:51 am
Hi,
would any one with a factory mgb hardtop be able to tell me the measurement from the top of the battery box to the under side of the hardtop.
Im building a rollbar but have no hardtop yet.but aim to fit one in the future.
Any help would be very much appreciated
Kind regards
Bevan
Last edited by Bman new zealand on Sat Sep 28, 2019 12:05 am, edited 4 times in total.
Dave Wheatley
Surname: Wheatley
Re: Height of mg factory hardtop
Post by Dave Wheatley » Fri Sep 27, 2019 9:53 am
Just my humble opinion, but I would wait until I had the hardtop!
1931 Austin 7 RM
1955 Standard 10
Bman new zealand
Forename: Bevan
Surname: Martin
Re: Height of mg factory hardtop (inside) 640mm ???
Post by Bman new zealand » Wed Oct 02, 2019 7:00 am
My rollbar has a bend in the middle of the roof.it fits under the softtop.
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Wed Oct 02, 2019 3:13 pm
Hi Bevan,. I can't give you an answer I'm afraid - I have a BGT - but someone on this forum should be able to help I think.
A couple of points: I think Dave is right - get your hardtop first as I suspect there may be some differences between different types? Secondly, it may be difficult to get a genuine "works" hardtop, so even if you get the measurement you are looking for, you may not get the relevant hardtop?
Best of luck with the build!
steve00136
Forename: Steve
Surname: Livesley
Contact:
Post by steve00136 » Thu Oct 03, 2019 6:57 pm
My works hardtop is not on the car at the moment but I put a bar across where the door shuts on the door jam pillar. I measured 400mm to the top of the inner roof about 20mm more in the centre - this clearance continues about 150mm towards the rear.
Hope this helps.
Just a thought that if you made it fit under a soft top surely it would then fit under a hard top?
steve livesley
Nottingham UK
my blog:- https://mgb.tips collected from all across the Internet
Bman new zealand
Forename: Bevan
Surname: Martin
Post by Bman new zealand » Wed Oct 09, 2019 5:54 am
Thanks so much for that.i will check where it ends up.thanks again
Bman new zealand
Forename: Bevan
Surname: Martin
Post by Bman new zealand » Wed Oct 09, 2019 6:06 am
Ive got about 15mm clearance from what you have described..awesome..i will start tiging it up..thanks so much.
Bman new zealand
Forename: Bevan
Surname: Martin
Post by Bman new zealand » Fri Feb 28, 2020 7:19 pm
Roll cage all finnished
steve00136
Forename: Steve
Surname: Livesley
Contact:
Post by steve00136 » Mon Mar 09, 2020 11:13 pm
That's one awesome roll cage !!!! Think next you want to tidy up that garage.
steve livesley
Nottingham UK
