Panel voltage stabiliser?
Re: Panel voltage stabiliser?
Post by Charles Farran » Fri Apr 05, 2019 4:40 pm
Dave,
If i understand you, you said the tank cap held good pressure overnight. Once the coolant has gone cold, i think you should just be able to turn the cap against the spring & rubber grip. Isn't the coolant (when the engine is/has been running) supposed to to be able to syphon back from the tank in to the block? If you have a dodgy cap this may affect this; might this be the cause of your small coolant leak which you might not spot when driving etc. (I may have a total misunderstanding of how the cooling system works, but i thought it worth mentioning as we are all here to learn from others aren't we)?
I am also aware from the BBS forum that there are plenty of miss-fitting caps around due to poor manufacturing / divergence in dimensions of the cap spring length , circumference of rubber washer at base of spring which do not fit the neck of the expansion tank very well.
Dave Wheatley
Surname: Wheatley
Post by Dave Wheatley » Fri Apr 05, 2019 6:55 pm
Charles you wicked man. Finding me more problems to solve!! When you think about it you are correct - the pressure should push the coolant back from whence it came when it cools. My pressure cap is 15lb - not sure if this is correct.
So, any more thoughts on this?
Charles Farran wrote:
> Dave,
> others aren't we)?
> Cheers,
> Charles
1931 Austin 7 RM
1955 Standard 10
Post by Charles Farran » Fri Apr 05, 2019 8:18 pm
Hi Dave,
The stated pressure on your cap is correct at 15lb . Whether it is fuctioning correctly at that pressure is another matter!
Post by Vic Butler » Fri Apr 05, 2019 9:06 pm
Charles, I agree with you about the poor quality of some of the radiator caps around.
Dave, many years ago some time last century shortly after I bought my B, I replaced the plastic plug in the thermostat housing with a brass one. I don't know if they are still available though.
Post by Charles Farran » Fri Apr 05, 2019 11:39 pm
The brass ones are & sold ( i think by Moss,MGOC & DAavid Manners) as an alternative to the plastic plug which very easily gets butched on removal. The brass one is used with a cork gasket as opposed to a rubber o ring type seal . I bought & changed mine last year and it has been leak proof with no tell tail drips over the thermostat housing. I always carry a spare cork gasket in the boot never mind a plastic plug & rubber seal in the boot as tiny & weightless.
Dave Wheatley
Surname: Wheatley
Post by Dave Wheatley » Sat Apr 06, 2019 8:32 am
> caps around.
Mine has a brass plug Vic and Charles.
1931 Austin 7 RM
1955 Standard 10
