Engine breathing and oil consumption.
Re: Engine breathing and oil consumption.
Post by Charles Farran » Fri Apr 19, 2019 12:58 pm
Dave,
Graham's solution seems (hopefully) to be a relatively easy & modest cost fix until you look to change the head to unleaded when you can use the opportunity to get at the tappet chests & possibly replace the front one. When i did mine i removed the exhaust manifold with the exhaust still attached, simply removing the front stay to the block underneath & swinging the exhaust away by a couple of inches that gives room to access the tappet chests.
Post by Vic Butler » Tue Apr 23, 2019 3:47 pm
I took my MG for a shakedown run on Easter Saturday after fitting a rebuilt distributor without vacuum advance. It ran like a bag of nails. Today I discovered the oil filler cap on the alloy cover was loose and obviously upsetting the breathing. I moved the distributor clockwise until the engine kicked back against the starter and moved it back a fraction when it didn't kick back. Another road test sometime. Of course,moving the distributor say 1 degree doubles that as the distributor is half engine speed. Unfortunately there is no rolling road or MG specialist around where it could be fine tuned and the mixture sorted out which I think needs enriching at higher revs.
Surname: Wheatley
Post by Dave Wheatley » Tue Apr 23, 2019 7:24 pm
Charles. Unleaded head mods nearer than I thought - see new post re Valve seat inserts.
Vic. Always remember - MG owning is fun!
Dave
1931 Austin 7 RM
1955 Standard 10
