Cover over Bendix
Steven collins
Forename: Steve
Surname: Collins
Cover over Bendix
Post by Steven collins » Tue Apr 14, 2020 9:31 pm
Just started to reassemble the engine/gearbox should there be a cover over the end of the starter motor bendix?
There wasn’t one when stripped down and I cannot find any reference to one. It just seems odd to leave a large hole?
S.
David Witham
Surname: Witham
Re: Cover over Bendix
Post by David Witham » Tue Apr 14, 2020 9:54 pm
I used to have a 1966 B with that type of starter and there was no cover. If I remember correctly there is a roll pin that holds the Bendix onto the shaft. The roll pin is a weak point.
Steven collins
Forename: Steve
Surname: Collins
Post by Steven collins » Wed Apr 15, 2020 8:59 am
Thanks David,
Didn’t think there was but you know that the mind plays tricks!!
Always good to get thing’s confirmed.
Post by Peter Cresswell » Sat Apr 18, 2020 12:47 pm
Hi Steven
As the hole faces backwards, the muck can't - or shouldn't - get in, and it does allow the bell housing to ventilate and let dust from the clutch plate wear to escape. Also BMC/BL never had enough budget to be able to fund a bung or better to produce a gearbox casing with a bulge cast into it!
Referring also to your thread about putting the engine back into the car, as you have an inertia starter motor you shouldn't have too much of a problem fitting it (as you seem to have done in the picture here) before trying to put the engine back into the car.
2011 MG 6 TSE Magnette
Plus 32 other cars since 1965
Steven collins
Forename: Steve
Surname: Collins
Post by Steven collins » Sat Apr 18, 2020 7:03 pm
Thank you Peter, all good information 👍
