Bare "plug" near brake master cylinder
Surname: Wheatley
Post by Dave Wheatley » Thu Apr 23, 2020 1:11 pm
I've just found a bare "plug" lurking out of sight under the brake master cylinder. 1978 MGB GT. Green wire and green/orange go to it. Searched the wiring diagrams but no luck so far. Looks to have stainless tip and is rust discoloured.
Anybody know what it might be?
Pic upside down! Tip is spring loaded. 2 pin plug and socket incorporated.
1931 Austin 7 RM
1955 Standard 10
Re: Bare "plug" near brake master cylinder
Post by Ian Fozzard » Thu Apr 23, 2020 5:12 pm
No idea really Dave, but could be a sensor for coolant or brake fluid? For level or temperature monitoring?
Someone with a late MGB will probably know!
Surname: Wheatley
Post by Dave Wheatley » Thu Apr 23, 2020 5:22 pm
Thanks Ian. It's definitely part of the original wiring, and won't stretch any furthur than the master cylinder.
1931 Austin 7 RM
1955 Standard 10
Post by Ian Fozzard » Thu Apr 23, 2020 5:26 pm
Maybe Victor will know😁😁
Post by Paul Scott » Thu Apr 23, 2020 5:40 pm
Hi Dave,
Brake Failure Switch apparently seems to fit the bill.
Pt No:aau2454
Page 53 Dual Line System item #2
Hope this helps
STAY SAFE
MGB Catalogue 2013.pdf
(4.98 MiB) Downloaded 26 times
Post by Paul Scott » Thu Apr 23, 2020 5:49 pm
Post by Paul Scott » Thu Apr 23, 2020 5:57 pm
On Page 24 in the cluster with the brake light switch/hand brake switch the Brake Failure switch is shown with the leads coloured Green + Green and Orange.
Hope this Helps
STAY SAFE
mgb.pdf
http://www.advanceautowire.com/mgb.pdf
(1.49 MiB) Downloaded 26 times
Post by Ian Fozzard » Thu Apr 23, 2020 6:04 pm
Sounds pretty conclusive Paul!! Would like to see what is fitted in that brake line union on Dave's car😬
Post by Paul Scott » Thu Apr 23, 2020 6:11 pm
Either in the union or under the master cylinder. But watching the moss video - I would say it is quite important..
I'm impressed with myself finding the correct answer (hopefully).
I read nearly every post that goes on and I am impressed with the knowledge that gets shared. So hopefully my little bit of input on this will help. Now ask me about an electrical cooker fault - I probably would not need to look anything up!!
STAY SAFE Everyone
Post by Ian Fozzard » Thu Apr 23, 2020 6:13 pm
Good job Paul😊👍
