Not 1 but 2 problems
Steven collins
Forename: Steve
Surname: Collins
Re: Not 1 but 2 problems
Post by Steven collins » Fri May 01, 2020 10:28 pm
Hi Peter, yes all ok now, helps when you turn the switches on!!
I didn’t run the engine for more than a minute or two. As you can imagine it ran quite lumpy with no air filters or choke connected - but it did run 🤗 and oil pressure is good, of course I will know more when I connect everything up as it should be then run it for a longer period of time.
