Fuel tank change
Re: Fuel tank change
Post by Vic Butler » Wed Sep 09, 2020 7:34 pm
Mario60 wrote:
Thu Sep 03, 2020 6:35 am
Hi Vic,
When you put back the tank in place, do you bolt it up, connect, fill with petrol and fire it up, or is there anything else or procedure you need to do?
Thanks in advance
Mario
Sorry for the delay in replying Mario. Fit the tank, connect everything up, double check and then put a couple of gallons on, switch the ignition on, wait for the pump to stop ticking, check for leaks then start up. If the pump doesn't stop ticking there's definitely a leak.
Mario60
Forename: Mario
Surname: Sciriha
Post by Mario60 » Thu Sep 10, 2020 8:44 am
Hi Vic,
all connected and now up and running again.
As usual many thanks for your help.
Kind regards
Mario
Mario Sciriha
1972 MGB roadster
1971 MGB GT (for restoration)
1979 Honda CB650Z
1975 Kawasaki S1C 250
1974 Suzuki GT380
1979 Suzuki TS125
JohnH
Forename: John
Surname: Howard
Post by JohnH » Fri Oct 02, 2020 2:01 pm
I did the same as Vic Butler above some 35 yrs ago and its still fine. A strip of compressible rubber eg rubber hose can close the gap along the front edge when installing to prevent road grit etc getting between tank and floor.
Always dip nuts and bolts in Waxoyl whenever reassembling everything. Bolts come out easily then even 40 yrs on and still have their shiny sherardised coating.
nathan_f
Forename: Nathan
Post by nathan_f » Sun Jan 17, 2021 2:45 pm
So I'm about to embark on this same project for my '78 GT. I've noticed now that at some point the rear part of the boot has been reinforced, I presume after some body repair work. The rear two bolts are not in place, with a L shaped piece of steel welded over the holes, and the tank being held in place with the remaining 7 studs. Should I go to the trouble of measuring out and re-drilling the holes to put the bolts through, or just not worry about it? Picture attached for some illustration...
(That should work for the picture...whoops)
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Sun Jan 17, 2021 5:05 pm
Nathan, no picture attached as far as I can see? O think it would be essential to offer any views?
nathan_f
Forename: Nathan
Post by nathan_f » Sat Jan 23, 2021 10:19 am
Not sure what happened, but I edited and it appears to be there now!
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Sat Jan 23, 2021 1:21 pm
I can't see anything unusual in the photo, but my BGT is a '72, so others may be better placed to spot something.
I would say that the tank is best held with all of the fasteners in place, so if you can re-drill the holes and use all of the bolts, then I would do that.
