Hi Guys,
Its a little way down the road before I'll need to actually implement this; but it has been bugging me and I'd like to know your thoughts.
Basically, I have a Webber DCOE-45 carb and an early 123 ignition which has a vacuum advance pickup.
Should I worry about the vacuum advance? Or is it worth tapping into both sides of the manifold then running to a y piece, then into the dizzy?
I could just run to one side of the manifold, but could that cause issues with having only alternate induction pulses?
Cheers!
Harry.
Webber DCOE-45 + 123 ignition/vacuum advance
Re: Webber DCOE-45 + 123 ignition/vacuum advance
Hi Harry
If the distributor has vacuum advance you will need to connect this up otherwise you won't get enough advance when the engine is pulling hard. Try contacting 123 ignition systems about where to take the vacuum from. I think they are in Belgium but see here https://www.123ignitionshop.com/gb/contact-us
Don't take the vacuum advance pick up from the inlet manifold as rubber bumper B's had. It needs to be on the air filter side of the throttle disc close to the disc.
