This is the first B that I've owned and worked and my intention is to do a thorough overhaul to get a car that's reliable for touring etc. I'm going over everything on the brakes, suspension etc replacing anything that is worn, broken or likely to fail in the near future.
I thought replacing the fuel lines would be straight forward, so ordered the pipe kit from a reputable supplier I've used several times. Came to fit the pipe that runs from bulkhead under the car back to the pump and found it was too short. Also, it had no union nut at the rear end.... Then I noticed my car has an in line connection next to the battery box and the second section runs up to the floor of the boot floor...
Thinking I'd been sent the wrong part (it can happen apparently
It was only after trawling through other sites it dawned on me that my fuel pump seems to be located unusually fully in the bottom of the boot.
I've decided to leave well alone as the copper pipes seem to have a lot of work done on their installation, but I'll replace the banjos seals etc when I fit the new SU electronic replacements.
Just wondered if anyone else has images of their fuel pump location in a GT? Any tips too for replacing the pump and connections, seals?
