Spitting through HS4 carb
Ian Fozzard
Surname: Fozzard
Re: Spitting through HS4 carb
Post by Ian Fozzard » Tue Jun 23, 2020 5:22 pm
Too far for me I'm afraid, but would have loved to have had a look!
Steven collins
Forename: Steve
Surname: Collins
Post by Steven collins » Tue Jun 23, 2020 5:29 pm
No worries thanks for the thought though.
I bought a new rotor arm and cap through MGOC they did ask what year did I purchase it as the newer ones (programmable 123) are different.
Steven collins
Forename: Steve
Surname: Collins
Post by Steven collins » Mon Jun 29, 2020 10:29 pm
Right, here goes update 1
checked 123 dizzy - NEW cap, pin inside jammed permanently up - not spotted when fitted 🙄 so cap U/S
Timing slightly out requires tweaking, however, 123 locked in solid pry bar would not shift it so even bigger pry bar initiated 😡
Air leaking around rear carb manifold 🤬
NEW spark plug leads - no 3 arcing on heater valve 🤯
123 dizzy replaced with 45 dizzy and re- timed, just as well I had a perfectly good one in the garage spares box🙂
Replaced NEW faulty leads with original working leads - now no arcing 😃
On order- manifold and carb gaskets😑
Hopefully when everything has been fitted and balanced it should run as it used to - well hopefully better- watch this space....
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Tue Jun 30, 2020 8:27 am
Hi Steven, thanks for posting back - most folk don't seem to bother, but posting back is what makes a forum valuable😊😊.
Sounds like excellent progress, fingers crossed it leads to a good conclusion! Multiple small problems can be extremely tricky to solve and lead to lots of false trails.
Steven collins
Forename: Steve
Surname: Collins
Post by Steven collins » Tue Jun 30, 2020 8:47 am
No problem Ian, sometimes by posting solutions to your own difficulties it can help others.
Just frustrating that when you purchase new items they turn out to be faulty,
aide - memoir
Check and recheck all new parts before fitting!!
Will update again when new parts arrive and fitted.
