MGB Roadster budget restoration & conversion
RumpledinkieVintageWorkshop
- Forename: Derek
- Surname: Harper
Re: MGB Roadster budget restoration & conversion
Part 20 of the MGB Budget restoration - we modify the front bump stops, replace the rear axle straps for shorter chrome bumper parts and find more rust!
https://youtu.be/l0VHNRgwiO4?si=xQd4SEHK-HnVrClW
1968 MGB GT
1968 Austin minor pick up
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
In part 21 on the MGB I look at the work we have carried out so far and how much money I have saved by repairing the body panels rather than just replacing them, it adds up to quite a lot!
https://youtu.be/J9e4RLFypK8?si=QeI_1Vv7cLYuodeR
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
Part 22 engine removal
https://youtu.be/JVzoZyab3Sw?si=6TuuSjOipgPA8fHE
Part 23
Finally get everything removed from the engine bay, ready to start repairs.
https://youtu.be/oCSxvVu_-lU?si=Lv84APWLBR-OlwME
Part 23
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
In this weeks video I strip the paint from the engine bay, apply etch and filler primer as well as shiny new coat of inca yellow paint, check out the progress so far.
If you enjoy the videos, please subscribe to my channel, thanks
https://youtu.be/5HO2fYLRbDg?si=9wUqxw3TM1Nksq9
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
In part 25 of the MGB budget restoration, I strip the heater box and pedal box of paint, make repairs and then apply a new coat of gloss black paint, before refitting them to the engine bay of the MGB.
https://youtu.be/fczfzp06rWI?si=lVA_PUWxwkmOHhP4
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
Everything reconnected but will it start?
MGB Roadster Budget Restoration part 27.
https://youtu.be/qVNW69XWSq0?si=J7y3XcJN1T9kP92u
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
Part 28 in the MGB Roadster budget build, the engine bay is transformed and looking good, we bleed the clutch and the brakes as well as applying fresh paint to some bits.
https://youtu.be/-BWsFQwA22M?si=18FVKOi01Zv8Ulwy
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
excellent work Derek.
- Forename: Derek
- Surname: Harper
In Part 29 of our MGB Roadster budget restoration, we tackle the "messy job" of stripping and respraying the boot area. Before we can focus on the exterior paintwork, it’s essential to get the internal areas protected and looking fresh.
Watch as we strip back old paint and underseal using wire wheels and sanding discs to reveal clean metal. We address surface rust, perform minor welding repairs, and tidy up previous work. Once the prep is done, we move on to masking, applying etch primer, and finally spraying the top coat in that iconic MGB inca yellow
https://youtu.be/bxIqgK4k-7E?si=FVElJdk4fLkr4Xii
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
- Forename: Derek
- Surname: Harper
Thank you, making progress.
1968 MGB GT
1979 MGB Roadster
1994 MG RV8
1979 MGB Roadster
1994 MG RV8
