Hi Scott. I thought I should let you know that Pete Cresswell has been absent from this forum for many months, not sure why, and I have been unable to find out anything more. I hope he may reply, but if he doesn't then don't be surprised.
What year is your MGB? The handling of the later cars with a raised ride height is quite different from the earlier ones, and requires some different solutions.
In my case, a 1972 BGT, I found a thicker front bar was all that was required to give good handling. I have adjustable telescopic dampers on the rear, set at their softest setting. No need for a rear ARB.
Remote Servo position
Re: Remote Servo position
