Rev counter
TomMGBGT
Forename: Thomas
Surname: Roach
Rev counter
Post by TomMGBGT »
Hi there can anyone assist, on starting my BGT 77 Model the Rev Counter doesn't,t operate but after a few minutes it works normally any suggestions appreciated.
Surname: Silk
Re: Rev counter
Has it been like this for a while or did it start following some recent work on the car ?
TomMGBGT
Forename: Thomas
Surname: Roach
Re: Rev counter
Post by TomMGBGT »
There,s been no work on the car only engine tune up
Re: Rev counter
Post by Ian Fozzard »
Different ignition system fitted? Tachometers work on ignition pulses.
Re: Rev counter
I always have to tap the glass to get my rev counter working. Have done so for years.
TomMGBGT
Forename: Thomas
Surname: Roach
Re: Rev counter
Post by TomMGBGT »
Thanks for your input will try your suggestions
Re: Rev counter
Probably not provided much for you to go on Tom. Intermittent faults like this are always tricky. I suggest checking all the wiring connections. If it is just a sticky needle in the instrument you could look inside, but perhaps best left to a specialist to overhaul the unit.
Speedograph Richfield have done similar overhauls of instruments for me.
TomMGBGT
Forename: Thomas
Surname: Roach
Re: Rev counter
Post by TomMGBGT »
Thanks Ian,have sent the Unit for repair to instrument tech.
