Lever arm damper capacity
David Witham
Surname: Witham
Post by David Witham »
Can anyone tell me how much oil an Armstrong lever arm damper is supposed to hold?
The dampers in question are the front ones with 2 arms but I wouldn't be surprised if the front and back held the same amount.
Re: Lever arm damper capacity
The repair operation manual just states to fill to the level of the filler plug.
Post by Ian Fozzard »
David, take a look at this:
https://mgaguru.com/mgtech/suspensn/fs110a.htm
Hi Ian,
I would agree with that link. When I upgraded the valves in my front dampers I bought a 500ml bottle of Penrite, and used a little over half of it. Penrite offer 2 versions; Shock Oil 1 for normal applications and Shock Oil 2, which is thicker, for competition applications. The bad news is that if the rears have the same capacity as the fronts you will need 2 x 500ml bottles.
For competition uses it is wise to leave a small air gap above the oil level because the oil will expand as it gets hot and pressurise the seals leading to leaks.
David Witham
Surname: Witham
I have now completely emptied and refilled the dampers. 200ml went into each one.
When I used to compete on sprints and hill climbs I fitted both uprated valves and number 2 oil in them. As I retired from that 8 years ago I have been changing back to number 1 oil but keeping the uprated valves.
At the same time I have taken out the short 550 lb/in springs and replaced them with longer 480 lb/in.
I am get it a bit softer for touring but not as soft as standard.
Somewhere in the depths of the garage I've got a pair of Armstrong rear adjustable lever shocks.
