Inlet manifolds
Ray Masters
Forename: Ray
Surname: Masters
Re: Inlet manifolds
Post by Ray Masters »
Hi Graham . Thank you for your reply . Any info you can give me , when convenient , will be useful and l will pass it onto my friend who originated the question. Ta , Ray.
ChargedAutoGT
Forename: Graham
Surname: Moore
Re: Inlet manifolds
Post by ChargedAutoGT »
here you go....
HOWEVER
Both manifolds are 12H2568
Flanges are 430 thou
except one which is 413
That's a big difference for an OEM part and whilst I cannot see signs of it, I do wonder if it's a DIY which I had not noticed before.
But, it's been done very well and must have had a pro milling machine.
Really not sure now.
lightning
Forename: Brian
Surname: Bailey
Re: Inlet manifolds
Post by lightning »
Hi folks.
I came across this problem when converting and rebuilding my imported U.S.1972 B. The original carbs (and fuel emission setup ) were removed and replaced with HIF cabs. The flanges on the inlet manifold that came with them were thicker than the standard exhaust manifold. To overcome this the difference was built up by welding half a washer to the thick washer that secures both flanges to the head. Hope this helps. ATB
PeterB
Forename: Peter
Surname: Bonsall
Re: Inlet manifolds
Post by PeterB »
This is not an unusual situation. As been suggested you need three washers, cut one in half and use one and a half washers to give you the correct thickness on the two exhaust/inlet manifold studs. The half washer goes against the thin manifold as a packing piece and then the complete washer is placed on top. JB weld or a suitable glue is suggested to hold the washers together but once in place and tightened they are not going to drop out.
