Wheel Nut Stripped
Wheel Nut Stripped
I've never seen this before in over 50 years of car maintenance. Tightening up my wheel nuts after having the wheel off and one nut wouldn't tighten. Took it off and the thread had separated from the body of the nut. The stud is fine and another nut tightened up nicely. I never overtighten these nuts. I just use a socket handle about a foot long. The car hasn't had any garage work done on it for years, so it hasn't been over tightened with an air gun. Weird.
Re: Wheel Nut Stripped
I've never seen that either! I always use a torque wrench and lightly oiled threads (not grease).
I bought four replacement nuts so I would have some spares and although they fit the studs and have the correct taper they are 1/16" larger across the flats. The originals are 3/4" and the new are 13/16". So now I have to carry two different sizes of wheel nut tools! I also lightly oil the wheel nuts Ian.
I've seen nuts strip like that quite a few times.
I bought a set of stainless nuts for my car. They're 13/16 like yours. They also feel loose on the studs. It's like the thread is slightly too large diameter. I rely on the large length of thread to provide ths necessary strength. Sofar, so good.
I tried stainless wheel nuts some years ago but I found that they were prone to seize on the thread due to some reaction between the steel stud and the stainless nut, I believe its called galling. I had a terrible job getting one off at one time so I binned them. And yes, I had oiled the threads.
I don't use any lubrication on the threads, it would have a significant impact on the torque setting, it is unlikely one could accuratly adjust or compensate for the difference. Also, the thread length has little effect after about a nut length, only to slightly increase the friction and reduce the clamping force....perhaps just the correct lubricant could offset this !!
