GAZ Dynamic Coil Over Suspension
Fjrden
Forename: Denis
Surname: Coulter
Post by Fjrden »
When I bought my 1975 Jubilee GT, in June, previous owner had done this 'upgrade' which had all new bits and bobs which was good. I like it on smooth road but on our forever pothole infested roads it crashes and bangs and you think it'd be damaged. The car was also lowered at back and front set to match. I'd prefer it a bit softer. Any ideas MGers?
Re: GAZ Dynamic Coil Over Suspension
My 75 B was also lowered by a previous owner. But they did not change the front bumpstops to the lowered type. Instead they just cut off the rubberd. This caused it to clang all the way up to my fingertips.
I changed the bumpstops. No more clanging or bump steer!
Paul ;0)
Fjrden
Forename: Denis
Surname: Coulter
Post by Fjrden »
Paul Scott wrote: Fri Oct 11, 2024 8:41 pm My 75 B was also lowered by a previous owner. But they did not change the front bumpstops to the lowered type. Instead they just cut off the rubberd. This caused it to clang all the way up to my fingertips.
Paul ;0)
Thank you for that I'll look.
Fjrden
Forename: Denis
Surname: Coulter
Post by Fjrden »
What is the sound you hear is it bottoming out?
Sounds like it's harming something
Paul ;0)
