Rocker arms
Posted: Wed May 24, 2017 1:04 pm
I've had the head skimmed on the B (1976 model) and in re-assembling I've come across a query regarding the rocker arms.
With the head bolted (torqued) down and the rocker assembly fitted, on certain valves the rocker can be rocked by about 1/4" to the point it clears the push rod completely and I can then wiggle that around and lift it in it's bore. As I rotate the engine this closes the gap but then frees other rockers to a similar extent.
Unfortunately my car and Haynes manual are in dad's garage 60 miles from where I type this so I can't look it up or show pictures on here but it feels wrong to me, the push rod could miss the rocker and jam between the bore and the ball of the rocker from what I can see. I just want to know what to look for when I get there on Saturday.
I haven't yet adjusted the tappets but it seems to be a lot of adjustment needed, I'm not sure how they were when I took the head off unfortunately and I've put everything back in the same order as far as I can tell.
The engine is pretty old and worn so I'm not expecting miracles I just don't want to blow it up!
