1972 BGT steering column bushes
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Tue Feb 05, 2019 8:39 pm
I am in the process of rebuilding my steering column - the semi-collapsible type - and thought I would replace the top and bottom plastic bushes. Just received two from a well known supplier (not Moss) and I find the internal and external dimensions of the bottom bush way too big (loose on the column and will not fit into the housing on the external column).
Anyone found any bushes which fit, or any advice? I may well just reuse the old original bushes!
IanF
Paul Hollingworth
Surname: Hollingworth
Re: 1972 BGT steering column bushes
Post by Paul Hollingworth » Wed Feb 06, 2019 12:39 pm
I had an advisory on the MOT for play in my top bush of the column. I bought a new nylon bush from Midland Sports and Classics. I had to cut it lengthways to get it in. Even then it was pretty tight on the shaft when oiled. After many years (about 15) and 30,000 miles its worn to be just about right now. The bottom bush is a felt and graphite thing. I found if you soak it in oil it recovers.
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Wed Feb 06, 2019 2:39 pm
Thanks Paul. Your set-up sounds very different to the one on my 1972 BGT. The original bushes (which I have just taken out) are both black plastic. I will take a look at Midland Sport and Classics and see if anything looks similar to what I need,
Paul Hollingworth
Post by Paul Hollingworth » Thu Feb 07, 2019 3:53 pm
Hi Ian,
I've just had a browse of the Moss catalogue and you are right that the collapsible column came in in 72, so my 71 roadster will be different to your GT. Moss do list the bushes for yours - top bush MGP1050B, bottom MPB1002, about £13 the pair.
I stopped doing business with Midland Sports and Classics when they refused to do counter service and wanted a minimum order of £10 (I think) plus postage. I only wanted a £4 exhaust mount. I had spent hundreds with them over the years but obviously didn't need local trade anymore. Their loss is David Manners gain, I think.
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Thu Feb 07, 2019 5:00 pm
Thanks Paul. I've checked on several MG parts websites and they all seem to be selling the same bush. Would be very interesting to know if anyone has bought one of these and found it fitted their column!
B&G have agreed to refund the cost to me so the bush will be back to them in the post tomorrow!
Ian Fozzard
Surname: Fozzard
Post by Ian Fozzard » Fri Feb 08, 2019 3:22 pm
Just as a further thought and a bit of information which may be of assistance to fellow MGB owners:
# The original lower steering column bush (semi-collapsible column 1972 MGBGT) consists of a double skin structure with cut-outs which locate the bush in indents in the outer steering column shaft. This double skin does allow some flexibility for a very snug fit inside the outer steering column. See photographs attached which I think should be self explanatory.
# The dimensions of the original lower steering column bush to fit the column are - internal diameter 25.6mm, external diameter 33.3mm
# The replacement bushes on sale generally (as far as I can ascertain) - Part No MPB1002, are all similarly made from a single piece of very hard plastic. The dimensions of this bush are internal diameter 26.5mm, external diameter 34.5mm. This lack of flexibility and these dimensions mean that this bush is far too loose on the inner column, and cannot be fitted into the recess of the outer column. Additionally there are no cut-outs on the bush to locate in the indents of the outer column.
It is of course possible (although very unlikely?) that my 1972 BGT has a steering column of slightly different dimensions to most others, and that these replacement bushes do generally fit the majority of Bs. Would be interesting to know.
I am also repairing the sliding (collapsing) joint on my column using the hot glue method as recommended by Gerry Masterman in the USA, if anyone wishes to have more information on this.
Hope this may be of some use/assistance,
IanF
