PDF attachments
Posted: Wed Mar 10, 2021 9:58 pm
Hi Paul
Is it possible to attach PDFs? I have a good document from Heritage, my insurers, about Agreed Values which would help the understanding of the thread posted by Ian Fozzard this evening.
Also I wrote a long reply to this topic and although it autosaved along the way and I saved it again just before hitting 'Submit', when I did i had to logon again and it was lost. Any chance of recovering this? If the time is needed it was at about 21:50 tonight.
Re: PDF attachments
Posted: Thu Mar 11, 2021 8:13 am
Thanks for your efforts here Peter, I look forward to reading whatever you manage to post.
I am thinking today of getting some quotes from a number of other brokers as advised here on the forum. I am practically decided that the "Artisan" policy I am currently being offered is not really suitable for classic car insurance! It's a disappointment as I have been with this broker for many years.
Re: PDF attachments
Posted: Thu Mar 11, 2021 8:40 am
by Paul Scott
Hi Pete,
If the below file works PDF's should work
Spring Run 20201.pdf
(184.12 KiB) Downloaded 4379 times
Lets see what happens
Have you tried attaching the file and got an error?
Do you know the size of the file you are trying to attach? 3mb is the limit
If it is bigger than this send me the file Pete and I will pop it up for download.
Re: PDF attachments
Posted: Thu Mar 11, 2021 10:07 am
Hi Paul - it is 663Kb. I'll try and attach it here first! That seems to have worked, so I'll now try attaching it to the main topic.
Any ideas on recovering my loooooong post?
Re: PDF attachments
Posted: Thu Mar 11, 2021 10:09 am
Posting the file has worked but it doesn't open immediately - it appears as a download in the tray at the bottom left of the screen.
Re: PDF attachments
Posted: Thu Mar 11, 2021 10:14 am
posting the file has worked!
Re: PDF attachments
Posted: Thu Mar 11, 2021 10:20 am
by Paul Scott
That is correct Pete
It will work as a download only
StaySafe
